hi gents
hoping to give an update (and maybe a summary when i finally drive a stake through this) but also see if i can get a little more intel from the collected brain trust?
i cleaned my harnesses and while i am not sure if it was wishful thinking but the EGR temp sensor harness may have been loose. so i snapped it in tightly and cleared codes with the accu-gauge (thanks @Tools R Us !). so code was off for about 30 blocks and upon arriving at the toyo tech the CEL went on as i pulled in. i guess rhisbis normal when clearing a code even if the temp sensor had been plugged in? meaning the ECM/U needs a cycle to get back the error codes?
anyway, i cleared it again, ran it down the street and it stayed off while three out of four readiness states cleared. so i was able to get an inspection and then run down and get a license plate (fwiw 2000 and earlier in texas can have 2 non-ready states).
pic of readout is below.
CEL light was off for two days and returned this morning. my tech seemed to be somewhat surprised the EGR readiness state cleared.
what i am wondering is if there is any significance that the EGR readiness state is “RDY” but the Catalyst E101 is Not Ready.
i have ordered the HUDDEXPO plug to run some more testing but also because it looks like a great kit (1995-1997 FZJ80 EGR Temp Sensor Test Plug Kit) and i DO now understand the readiness states and the EGR delete testing, why EGR may be not so great etc, etc. i also get that i only really need to deal with the code at my next inspection i guess (?).
anyway, am i still doing the Standard Operating Procedure if i want to make sure the code is cleared before i do any other testing? meaning check the various valves and the hoses and the ports etcetera? or does the one not ready state have some significance for troubleshooting?
basically i think i have one more (or maybe two) year for smog testing (24 years and older no smog testing) so i’d like to sort this as best i can now while my brain is in it.
am i missing anything? i mean do these readiness states have any significance other then inspection?!
THANKS
jon
THANKS
jon
