...And finally ensured that the distributor rotor pointing to #1 plug wire.
So roughly 11 o'clock?
BTW: Correction. IT was more like 1 o'clock, not 11 o'clock.
Do I need to redo all the timing stuff like aligning the dots on the cams, rotate the pulley to 0*, ensure that #1 piston is TDC? Or simply pulling the distributor and setting the rotor would suffice? Assuming every thing else is fine. Also When you pointed yours to 11 OClock, was it pointing to #1 or #5 plug wire?
s (although I can't drink)
