Only other thing I could suggest that you've probably already done is check intake for leaks and make sure everything is tight on the air cleaner. Also service the injectors.Cleaned it and replaced the 02 sensors
Good point, Ill check the flowPressure and flow are different, how are your fuel and air filters?
