P/S question
Georgia Tech
FJ60 high pressure hose, which is what most run with minitruck setups and saginaw pumps, has a 90 degree bend. 2.25" from tip of the flare to the inside of the bend. About 3/4" of that is inside the pump when installed.
I do not know of the flare fitting matches up with the tercel pump, but i would not be suprised if it did.
Thanks!
Thanks for the info. I will look at that option. I think I have seen you post about going to Tellico in a couple of weeks. Are you going? We will be there (CottonLand Cruisers). Hope to see you there.
Jeff
CottonLand Cruisers
78 FJ40
CruisinGA said:
Good deal, I think you will see me up there. I'm with david's (dd113) crowd coming from Atlanta.
Not if we can lose you first!
Jeff, the 60 hose should work, I also have a pile of mini hoses around the shop which all should fit if the 60 bend is wrong.
Hose
David,
Throw one in the truck if you don't mind. That is if it won't put you over the weight limit! I've known you to carry a beer or two in the rig.
Thanks!
Jeff
CottonLand Cruisers
78 FJ40
