P/N for TRE’s ?
Does anybody have the PN’s for both the TRE’s on a ‘93 ? If I grab the the tierod, how much should I be able to twist it back & forth ?
If the rod moves easily they are shot, should be hard to rotate by hand. I have used a couple of these and it is just so much easier to replace the whole thing. Would have been a real PITA to remove the ends from my tie rod with the rust. Whole assembly is made in Japan with 555 ends. They are $86.79 on rockauto right now.
Eric
Here is the full TRE Kit
P/Ns for just the tie rod ends are 45046-69135 driver side, and 45047-69085 passenger side.
Another option is for about 100 bucks more you can get an upgraded steering kit that will come with all 4 TRE Here
Thanks for the P/N’s
Finally got the parts & the old ones off, counted the rotations, and the new TRE’s back on
But did not keep track of the end that came off the DS or PS. Is there a standard or OEM, as to which side the left hand thread & right thread is installed ?
Relay rod can only go in one way bc of the steering damper. It dosnt matter which way you put the tie rod in.
The tie rod ends P/N are listed driver and passenger side, but it’ll work either way.
