Evening all,
Been having some issues with overheating the past few weeks and not sure where to go now.
I've got a '93 1FZ manual with 320 k's.
Basically, was headed to Killarney a month or so ago for the trail ride. Was fairly loaded up with camping stuff and had a small dirt bike trailer with two bikes on. Got most of the way up Cunninghams Gap (a notoriously long hill up a fair sized range near Brisbane) and the temp needle started to climb. Foolishly I didn't turn the heater on, but kept going intending to just pull over. Pulled over before the needle hit the red, turned it off, let it cool down and went up the rest of the way with the heater on and had no dramas.
A small amount of coolant (few hundred mls maybe) had come out of the overflow. I think it was just starting to bubble so would of been fairly hot..
Drove the rest of the way there and back with no dramas and no heater on.
Still had plenty of coolant when I got to Killarney and tested the fan hub was locking up by getting my girlfriend to turn the car off while I watched it. Fan stopped immediately with the engine.
Since then I've replaced the coolant, thermostat and fan hub oil. Start with the easy stuff.. Pretty sure the fan hub was ok, coolant looked nice and green (no bits in it) thermostat was a little rusted though. Tested it in some boiling water, was opening but not sure if it was opening fully.
I also hosed out the block and radiator, but little to no crap came out. I was able to put the garden hose on full noise through the block and then the radiator with all that water passing though. None backed up and came out where I was hosing it in.
Loaded the car up yesterday with my dirt bike rack (not trailer) hammered up some hills (in the car) and all seemed well temp wise.
Went to the beach today and didn't have the same luck. Temp was fine on the inland tracks, was giving it some in low range through soft sand. Only doing about 20-30 kph and tough going for an hour or so with no dramas. Got out onto the beach, drove up about 5 mins, parked up, swam etc. Headed home down the beach about an hour later. Got about 5 mins down the beach and temp starts to creep up. Mine usually sits a fraction below halfway, it was now sitting on a fraction above halfway. Flicked the heater on (learnt from last time!) and it stayed at a fraction above halfway for the 20 mins further down the beach. Had to wait in a small line to get off the beach (school holidays) and in that 5 mins the temp was back to normal at a fraction below halfway. Had the heater on still though and engine running.
I thought this was a. Annoying and b. strange. Why was the temp fine in the hard going on the inland track and not fine on the easy going, hard sand on the beach? Was also moving a lot quicker, around 50 kph on the beach. I tried a few things on the beach to bring the temp down (speed up to 60, slow down to 40, change down for high engine rpm, change up for lower rpm etc) but nothing worked. Temp stayed a fraction above haflway until I stopped in the line up to exit the beach.
As soon as I was safely off the beach (I have a small paranoia of breaking down on the beach and the tide coming in) I pulled over and checked the fan, stopped as soon as the engine was switched off and the coolant level, still fine. There was a short inland track (around 10 mins) to get from the beach to town which was probably the softest sand I saw all day. Had to give it a bit to get through, but no temp dramas. Heater was also off.
Inflated tyres and drove the hour home with no issues.
Sorry for the epic essay, but I'm really unsure what to do next.
Do I even still have a problem?
Am I being paranoid?
I do a fair bit of camping etc with the car so don't want to have a major drama somewhere remote and watch the sea engulf my car.
Anyone that can shed some light on the situation would be greatly appreciated. I know the radiator and maybe water pump could still be causing problems, but I'd like to narrow it down before randomly replacing stuff if possible.
Cheers!
P.S. please excuse the awful pic of my temp gauge, it's the best I could do at the time..
Cheers!
