Overheating Help!
OKLAHOMA cITY
My truck started overheating the other day, and not sure what the culprit is.
I have already changed the thermostat, so that is not the problem. and the radiator was repaired about 4 months ago. (but it is on it's last leg)
It runs at a normal temperature when I it first warms up. and it will idle at normal temp for quite a while. and if I drive pretty slow, it will be okay for a while.
the problem starts when I driv the truck normaly. as the revs build, so does the heat. and it gets into the red. And it is somewhat sporadic.
any ideas?
Thanks
Kent
Replace the radiator, hoses, fan clutch, flush the system REAL well, and go from there if you don't how long it has been since any of that work has been done. I wouldn't drive it much in that condition either...My money is on the radiator as you've already said it is suspect at best.
livelarg, I have a new OEM radiator and water pump I ordered from CDan sitting in the boxes at my house. I have no use for either now so before you order one PM me and I will make you a deal.
That happened to me and in my case it was the radiator. Changed the radiator and the overheating problem went away. I went with the 1994 brass radiator from cdan. It's been 2.5 years since that happened.
Didn't change the fan clutch nor the water pump.
x2 about the radiator. usually the culprit with your symptoms. the radiator is most likely restricted through most of the bottom and doesn't let the coolant flow enough for normal driving, but is ok at idle.
LOL. So your fan clutch has 144K miles on it? What exactly are you waiting for? You know they have a lifespan of around 100K miles. You know the stock temperature gauge is useless. You know it is a crucial part of the cooling system.
Whatever. Not my problem.
After all of that, it ended up being an broken belt that goes to the wter pump!:doh:
anyone have the part number for the belt that goes from the crank-alternator-waterpump/fan?
the part stores here only have 2 belts listed for my truck.
Thanks for all of the help!
Kent
Fan belts (they come as a pair) is 90916-02353-83
Might as well replace the A/C belt too while you're in there (99332-10910-83)
Holy cr*p! :eek:
How long were you running like that??
Unless it was one, very short instance, I'd be *very* surprised if you don't have serious engine issues at this point. (Not that I would wish that on you or anyone.)
Good luck,
Curtis
