Overhead compass /Alimiter
I have a JDM, 1992 HDJ-81, the overhead compass does not apper to work ,aways shows the arrow at west. . Any ideas on how to reset it? As well as the alitmiter. It appears to have power as the light works.
:confused:
Thanks
John
The altitimeter is manually adjusted by turning the little knob to the left of it. If your compass is "stuck" in one direction it's broke. There are two adjusting knobs for the compass and if they don't move it it's toast.
I can calibrate my altimeter ok (not that it's much use really) but my compass seems frazzled also... I can adjust the needle but it won't point true consistently. Maybe they just suck.
Do you have a roof rack on it?
No I don't have a roof rack.
The adujuster knobs turn and the dial moves.
Does it have a fuse ?
If the needle moves when you turn the knobs the compass has power. If it won't adjust either the compass head or the magnetic field sensor in the roof is wacked.
That's why the roof rack question. A steel roof rack can make the sensor a little goofy and magnetic CB antennas really blow it's mind.
The compass needle is very sensitive to adjustment. When I got my HDJ81, I was certain that the compass was shot. According to the cruiser the sun rose in the south and set in the south east. After several months of turning the dials at stop lights, I finally got the silly thing rotating and pointing in the correct direction. I am out of town at the moment but will look at the settings of the dials and get back to you in a couple of days.
