I had a problem with intermittent hot air from the heater. My first thought was low antifreeze but I haven't noticed any leaks.
Checked the coolant level and, sure enough, I had to add quite a bit of coolant.
Also noticed that my overflow reservoir was full or over full.
My first suspect would be a bad radiator cap allowing the expanding coolant to enter the overflow reservoir but not allowing it to return as the engined cooled. Once the reservoir was over full, the coolant would then be forced out and be gone. No leak was noticed because it most likely was happening while driving.
The radiator cap is less than 6 months old and is from Toyota.
Could there be another reason for the overflow reservoir to fill up and not be returned to the radiator?
