I'll go right over it and see what I can find..Is there a way to tell if it's. The genuine radiator markings ect? Also I might add a temp gauge I can read... Anyone recommend a gauge?
I think factory was either Koyo or the Toyota radiator plant (can't remember the name right now) but not sure what went in what or the markings. I replaced with the brass version of the Koyo. The aluminum version is supposed to net you a couple more degrees of temp drop.
As far as the temp gauge goes, the numbers I posted of 225-235 were via ultragauge, the damn dash gauge stayed near the middle. It went up about a needle width.
I went down to the beach to test out my new fox shocks today. Ran the soft sand in both hi and low, never went over 190. This is with a fresh blue fan clutch, fresh coolant and a fresh HG. I wasn't out too long but plan on doing it again and will report back after a longer drive. Tires were aired up at 38psi, will lower the pressure before tomorrows run. These numbers were checked off of a blue tooth OBDII dongle and the Torque Pro app.
I will say that before my temps seemed to run higher before I did the HG, but I did not have a means of checking it. I am really digging the bluetooth dongle. Super handy and easy way to check temps etc. Can't beat it for $17.
think mines obdI so i cant use the bluethooth scanner ...i guess all sand is different ,but the sand i was on was soft to the point of wheels spinning and if i stopped i would have been lucky to get it going again without letting the tyres down
If it was the thermostat then "Back off the beach and the temp came back to half In about the same time.." would not hold true. Looks like a problem with the radiator.
Could still be a faulty thermostat, quite often the thermostat will only open to a certain level from normal driving around town (low loads). but it can get sticky and not fully open on the occasion that it get a much higher load. As soon as you take the extra load off (come off the sand) then it cools fine as normal because the thermostat can open enough to deal with that amount of load. Having said that I would definitely be looking at the rad also. If you do the radiator, I would throw a thermostat in just to be sure (there cheap).
Was the fan clutch a factory replacement? I tried a Napa unit and it was junk, ended up replacing the oil in the original and tossing the replacement. Also look at the spring thing on the front of the clutch, if it looks rusted or dirty it needs to be cleaned. I used a wire brush to get in there as much as possible and then put some oil on it to keep it from coming back.
update..got new genuine thermostat $18 and cap, only one left in country so they said at toyota.. looks a lot better unit than the motorad one that was in there someone must have changed it at some stage..motorad opened at 77c and new toyota opens at 82c..i have taken the radiator out to try to see if i can fush it better..the is some evidence of small spots of scale in tubes(just looking through the cap) i think i might just get a new one..toyota said $1200 for a new one lol...found a koyo that looks like a good option on ebay,for $350
That Koyo radiator sound good for $350. Probably wouldn't be worth getting yours pulled apart and cleaned for that price. It would definitely be worth replacing it while you have it out, because if it is still the original radiator, the plastic tanks don't last forever, the top tanks usually split after 10-15 years max.
Just a tip when putting the new thermostat in. you may already know this but, you will notice the little loose rivot thing that is through the main outer part of the thermostat, make sure when you install it that the rivot if at the top (or as high as you can get it) as this is designed to bleed the air bubbles out of the system even when the thermostat is closed.
Yeah thanks I think a new rad while I have it out would be the best option.. Wasn't sure about the hole in the thermostat but I put it up so.. That's good
update..got new genuine thermostat $18 and cap, only one left in country so they said at toyota.. looks a lot better unit than the motorad one that was in there someone must have changed it at some stage..motorad opened at 77c and new toyota opens at 82c..SNIP
I think the picture makes clear which is the better value part...
5 degrees centigrade difference in opening temp will make a big difference. A new radiator is good insurance at this point even if it's not the primary culprit.
update..got new genuine thermostat $18 and cap, only one left in country so they said at toyota.. looks a lot better unit than the motorad one that was in there someone must have changed it at some stage..motorad opened at 77c and new toyota opens at 82c..i have taken the radiator out to try to see if i can fush it better..the is some evidence of small spots of scale in tubes(just looking through the cap) i think i might just get a new one..toyota said $1200 for a new one lol...found a koyo that looks like a good option on ebay,for $350View attachment 1001416View attachment 1001417
It does get pretty hot here, and I tend to push my rig pretty hard all year round. My new Koyo 1918A cast about $250 delivered and it has done a great job of keeping the temps down. John
Fan clutch is a definite check but sand will cause overheating on it's own if not deflated like you already found. If you are on big tires, heavy load, etc it will only make it worse. Dropping the xfer to low also helps.
success! just loaded it right up on the beach in high range very soft sand, tyres up hard..temp needle didn't move..only thing is.. I cant be sure what fixed it ,but i'm leaning towards radiator..and thermostat close second, although the radiator i changed did look to be fairly new..I also put in new genuine thermostat plus rad cap..new radiator was koyo brass copper type 3 row..thanks guys for your help!
