Outside Temp Display Stuck?
az
Outside temperature display looks to be stuck around 93 degrees. Made it's way to 102 but then back to 93, 97ish or so after restart. Anyone else have this happen? Thoughts? Reset? Manual didn't show much.
Maybe you can check if there's something obstructing the sensor or if it's covered in dirt/grime
Yesterday we had several trucks go up Corkscrew Pass at LCDC. At least two of them, a 2010 LC and a 2020 LC had the outdide temp readings get stuck on 46 or 47 degrees all day, until returning to Silverton in the afternoon. We spent most of the day at 11k-12k feet. (For the record, it was much warmer than 47 degrees, decidedly hot.)
I guessing this is altitude-related and that other LC owners have experienced similar phenomena?
Almost every time I took my 2011 LC 200 through a carwash, the outside temperature would read 10-20 degrees low for a couple of hours. No such issue with 2016 and 2021 models.
