Our rig won't unlock
Socal/ I.E.
My truck will not unlock with the remote. At the same time this started I noticed that when the drivers door is closed the light on the dash says that a door is open, When I open the door the light goes away. Today my wife got locked out of the truck and she could not get the key to unlock the door. I had to go to her rescue and I struggled with the key for ten full min. Before I finally got it to work. I believe that we are using the original key and that it is worn to the point that it is difficult to unlock the door, but the key works fine in the ignition so I am not sure if that adds up. I realize that there are a couple problems here but I needs your advise on what needs to happen.
Thanks
This happened to my wife when we had our '93. Neither the key or remote would unlock the door, not even manually from the inside. I had to take it to the dealer (ouch) and $500 later it was fixed. I believe the dealer replaced the whole lock unit as I was told they don't sell the parts separately. I also heard this was not uncommon. I hope someone will chime in with more info for you but I think if you are not in a hurry and can find the parts at a salvage yard, you wont have to buy the whole unit. Good Luck!
was it a problem on all three keyed locks?
Do you lock the doors with the power lock button on the door or the key fob? Mine did this to me the other day (luckly my rear hatch doesn't lock/unlock with the power door locks) and I found the power lock button on the pass door stuck in the "lock" position. I popped it back to it's normal resting place and all was well again.
........ Today my wife got locked out of the truck and she could not get the key to unlock the door. I had to go to her rescue and I struggled with the key for ten full min. Before I finally got it to work. I believe that we are using the original key and that it is worn to the point that it is difficult to unlock the door, but the key works fine in the ignition so I am not sure if that adds up. I realize that there are a couple problems here but I needs your advise on what needs to happen.
Thanks
It's possible on your door lock, using the key, that since it's exposed to the elements more than your ignition switch that it might just need some cleaning & lube. Most locksmith shops will sell the stuff. The kind that I got (years ago - they must have improved on it by now) came in a miniture spray can with a tube that you can insert directly in to the keyhole. Since you didn't use it much because you were using the remote, it's gummed up and needs some attention.
I've used WD-40 for this before, worked great.
