Original battery connectors?
I think my battery connections and cables are original to my 94' LC. The connectors don't have an obvious bolt or nut the tightens down on the cable. Do these twist off somehow?
I would like to put in new connectors, but not sure how the old ones come off????
Thanks
A pic would help us to help you...the clamp bolt may be corroded. That could be cut, and a new bolt inserted. But may have to go with new clamp, depending on condition. That opens up a wide range of options.
This is very close to OEM, without the price Amazon.com: Deka OEM Lead Free Replacement Battery Cable Terminals (2 Pack): Home Improvement
This is expensive, but great connection conductivity without swaging a copper eyelet, which is then bolted to the clamp. Amazon.com: DB LINK BTP2 Positive Battery Terminal: Electronics
These military style clamps allow you to bolt lots of battery draining accessories directly to your clamp Amazon.com: Pico 0810PT Military Style Top Post Battery Terminal 1 Set Positive and Negative per Package: Automotive
Who knew Amazon had such a selection?? Don't forget to wire brush your terminals free of corrosion, then buy a spraycan of ignition sealer from your local auto parts store, and once you have everything back together, spray your new clean battery terminals and clamps to prevent corrosion in the future.;)
It isn't too bad, but the clamps/connectors are greasy/dirty/worn/and overall just in bad shape and worth replacing. However, if I cut them off there won't be enough wire to reach the terminals with the new clamps. How much of a pain would it be to run new wire? These wires look like they are factory sheathed all the way to the fire wall. Not sure I want to start cutting that stuff up just yet.
