Need some advice before I start the big engine rebuild. My 97 threw at least one rod bearing, may have more damage below once I get her pulled apart. My biggest concern is the crank condition.
The current plan was to tear mine down and send out the crank if needed and have the head reworked. Then these two came up.
Options for donor engines
1) 180k miles, no oil pans, accessories, sensors, oil pump, manifolds, valves, or valve springs. Nothing extra, no valve cover, Not protected but kept in shop. Removed from truck bc of a "tick"-$500
2) 289k miles, includes everything except for one emissions device. Includes manifolds, shields, brackets, everything. Was running when removed. $1200
So question is, which way would cause less pain and $ but provide the most reliability?
Thanks for the advice.
