Optima Red Top
A note on your alternator wires. I have a GM one wire set up too. And I just have one wire going from the alternator output to the battery. The other two connections are left open. I have been running this alternator connected like this for about 15 years so far without any problems. This is how the shop that slod me the alternator told me to connect it.
If the alternator sits unused for a long period of time, it will loose it's residual magnetism necessary to self excite. When this happens, start the motor, run it up to the RPM necessary for regulation, normally 1600 RPMs, but if you are running the stock LC pulley, it will be closer to 2500 RPMs. Then momentarily connect all three connections together. At that point the alternator will excite, and if it runs for a bit, will work on its own again.
It is good to get rid of the dangling wire :). I would have to look at the drawings to be sure, but that wire touching ground may have caused your alternator to attempt to raise the ground level to 14.5 volts, which it would never be successful at doing, but may take out the rectifier and battery in the attempt.
The rectifier is four diodes that turn an AC sine wave, which is alternating "humps" above and below 0 Volts, into a signal with the same number of humps, but they are all on the same side of 0V. So a signal that continously swings from 0 to +15 to 0 to -15 to 0, gets changed into a signal that goes from 0.7 to +15 to 0.7 to +15 to 0.7. Normally capacitors are used to raise the 0.7V to a level closer to the desired level, making the rectified DC closer to true DC. But I think in our application (car battery charging), the only thing necesary is that the level never goes negative, and it looks DC if you check it because as long as the battery is connected, the level will not drop below the battery level.
Hope that helps,
gary
Thanks Gary,
I've read about those types of alts that are self exciting and I get what you mean. This one I am running needs that feilding wire to be hot in order for it to energize at all. The little dangly wire will eventually be hooked up to a dash batt light but in the mean time I just pulled it.
So basically, if I were to get rid of that one fielding wire it wouldn't work at all.
I think it's fixed...
Thanks again. :beer:
