opinions needed
arkansas
I did a rear spring flip, soa, sr and will be running 37"mtrs. What do you guys prefer....having the rear of the rear fenders keeping the original factory lines or having the rear of the rear fenders cut to follow the rear of the front fenders lines.
I'm with the other guys keeping the stock lines, Only way I would start cutting the orginal metal is if I had a torn up body and chasis that couldn't be saved. I've seen some guys running 36's on the SOA rigs with room to spare, you should be ok with the 37's and could go with an inch or so longer shackle to make up the difference.
I did a little cutting with the stock lines. i used a large coffee can for the lower raidus on bottom of the rear fender. more pics on my build up thread. Mike
after cut... the blue line was where I was going to go, but decided not to go up for now. I took like five inches off the rear and made a cardboard template for the curve.
