Open sunroof without battery?
Modesto, CA
I have no motor in my LX currently. I just noticed the floors are wet and mold is growing on the carpet. I'm assuming it's coming from the sunroof plugs but since there's no motor and the battery is pulled I can't open the sunroof to clean out the drains.
Any help would be appreciated.
I did pull the plugs under the body and water did drain out.
Found this in the e-copy '96 FSM on page BO-68. I can't insert the picture, but it looks like the access is in the right side of the personal light assembly by the rear view mirror. HTH.
(c) Manually operate the moon roof by inserting a special crank−shaped screwdriver into the hole and turning the drive shaft.
Found it but can't get it to turn.
