Only drivers side window works from master panel
Fort Lauderdale
Hi all, ever since I’ve owned my 99 LX, only the drivers window has worked from the master panel. The rest of the windows work from their respective panels.
Things I’ve tried:
-checked wiring loom in door hinge for wire breaks
-tried to reset windows individually (holding up for 10 seconds and down for 10 seconds etc)
-bought new master window switch- same issue
- checked fuses
I think that’s it, but it’s also been about 6 months since the last time I messed with it so I may be forgetting something else I did try.
Any other ideas?
There's other threads on window switches you can search for and dig into. If you replaced the whole DS switch panel then I'd say your issue isn't the contacts in the switches, I'd starting testing with a multimeter from the DS door to the other doors, checking for continuity.
