onboard air
I have searched all over the forum and have yet to find a good dual compressor onboard air wiring and plumbing diagram.
Anyone have one that they would like to share.
thanks,:)
When you say "dual compressor" what do you mean? Two electric, one electric one York?
If its two electric, just run them parallel to each other and plumb the fittings into a Y. Kinda like what Extreme Air does:
10. ExpeditionAire Portable Compressor
I actually meant a hard mount diargram, baiscally the compressors with pressure switch and plumbing to air tank and to guage inside.
It seems very simple, I am just not sure if I need to run a line from each compressor to the tank or just to one union.
Just run one union for the hoses. And one block for the wiring and switches. There isn't a need for two runs unless you are running one compressor in the front and one in the back.
thanks,
so can i put the pressure switch right after the union on the tank side rather that screwing it into the tank, so it has some flexibility?
Also can I use that block from slee? or is there another less expensive block that you would recommned?
What do you mean "flexibility" of the pressure switch?
For blocks, take your pick:
Manifolds | Air Compressor Accessories | Air Compressors | Northern Tool + Equipment
Well,
I have seen the vair with the relay and also the simple pressure switch. Not sur eof the difference between these. I have some set ups where the installs where they thread the pressure switch directly into the tank, which seems like it may be easy to break off if a rock hits it.
Viair - Your Vital Air Source.
rule of thumb is to not put the pressure switch on the bottom of the tank, if anything, put a drain petcock in, or a regular cap. that way you can drain the condensation out once in a while. it also keeps you from breaking off your more expensive pressure switch. i would try to keep the entire tank from getting hit by rocks.
just my .02
just my .02
thanks
but can i put the pressure switch on the block?
one thing I'd suggest is this: place a one way check valve at the output of each air compressor then go into a tank/union/whatever. This way, one compressor doesn't try to fill up the other air compressor and neither leaks down the system's air pressure when not running. Another benefit to this is that if you had to remove one air compressor from service, the check valve will prevent the air from escaping out of the system.
With that said, I like the flexibility having a manifold where everything comes into and leaving from. For example see mine, Picasa Web Albums - A. - Landcruiser p... and another one Picasa Web Albums - A. - Landcruiser p... This way, you can mount your air press gauge, press switch, blow off valve, etc all in one, easy to reach spot.
I used to run a York and a Quick air II as a backup and they both fed this manifold. A selector switch under the hood was used to select which air comp would run based on the press switch feedback. The QA has since been removed.
For the best use of my hard earned money, I'd buy two MV-50s vs any other single electric air compressor in the market currently. The money saved can go toward purchasing push in fittings, 1/4" DOT air brake hoses, press sw, blow off valve, manifold and other mechanical stuff from McMaster carr. I would only use the push in fittings that are so easy to use and come in various configuration. No more hose clamps, ugly, large fittings everywhere when you go with the 1/4" DOT air brake hose and push in fittings.
Just my .02 cents.
Just my .02 cents.
what kind of pressure switch are you using?
thanks,
Everything past the check valve will have equal pressure, so it doesn't matter where you put everything - I prefer a manifold to make it all very accessible. But as stated above, do not put the switch on the bottom of the tank - you will have oil/condensation that will mess with it.
I sourced many of my parts from mcmaster.com.
-Phil
Pressure switches can be found on many websites. Mine are from Sun Products Quickair 80/105 psi range. I use this particular range of PS so that i don't have to use a regulator to step down the pressure for tools or air lockers.
HTH.
