There is rotor seasoning and pad bedding. Usually, people skip seasoning as it is a multiday process and not practical to do.
Bedding... it takes ~300 miles of mixed driving, and this is why after you get a brake job at the dealer, they recommend driving more careful those miles.
Obviously, you don't have that option now, so you'll have to do a performance brake bedding. The tricky part is that you are using street pads that do not operate well at high temps.
Anyway, you do need some roads with little traffic and a 50mph or more speed limit and as fewer stops as possible. That sounds like a state road and that's what I use. It is also advised to time this when there is light or no traffic. I usually do this late in the evening or at night.
If you search online, you'll find many variations, mostly for regular street pads/cars. Here is what my procedure is, a concoction from docs from Brembo, IPD, PBR, and the forums I frequented over the years. I used this on all my vehicles for many years, but I have performance pads, except for the LX rears that are OEM. I do use this procedure on OEM pads to but your milage may vary. What I'm saying is that you should use your own judgement as I'm not familiar with your truck (looks like it is modified) and I do not have experience with bedding front OEM brakes as my truck has TRD BBK Tundra brakes.
The idea is to gentle warm the brakes, then thermocycle the brakes a few times, and finally cool them down in a controlled way.
During the procedure you should never lock your brakes or activate the ABS!
Unless specified to stop, do not completely stop as that will deposit pad material on the rotor! Off course you should stop if you have to (traffic, stop signs, etc.).
Pick your roads wisely so you are not speeding. You should pay attention to your brakes not where the cops are.
Cooling brakes is not done by parking the vehicle but by driving at highway speeds.
Keep the windows down when doing it so you can use your nose. No smell means you are not heating them enough. All pads smell even if the ones claiming they are prebaked. If you do not have experience with this the smell might feel excessive, but it does smell awful.
I start by warming up the brakes by performing 2x 50-65mph to 5-10mph stops, light to medium. If you have soft pads, I'll probably use 10x or more 30mph to 5mph stops to be gentler.
Next, I do 2x back-to-back heavy stops from 65mph to 10mph (or 50mph to 5mph for you) at a point just prior to wheel lockup or ABS actuation.
I drive for 10min to allow the brakes to cool.
Then I warm up the brakes again with 3x light stops in succession.
Finally, perform 6-8x heavy stops in succession from 65mph to 10mph (or 50mph to 5mph). I push the brakes as hard as possible without wheel lockup or ABS actuation. You may want to scale this down to half for soft pads.
Finish the bedding procedure by driving at least 10min (usually 20min) at highway speed, allowing the brakes to cool to normal operating temps.
Park and let them sit for at least 1 hour to cool down.
Or if you have gadgets, PBR recommends warm up the rotors to 120F, then do 1x stop every 1mile from 50mph at 0.4g
