On the Fence
Rosamond Ca.
Being new to the FJ80 crowd, and more specifically the 3FE engine as well, I have MANY questions,concerns, and ideas. Mostly these revolve around the smog equipment, and mileage and "performance".
I have spent hours reading the FAQ's and related threads involving de-smog, but none that I have read have any conclusive information on mileage gains. Maybe I have just missed it, and if so someone please PM me with a link to where this info may be. It appears that freeing up the exhaust in conjunction with advancing the timing, and MAF adjustment, is truly the best gain to be had. Obviously the standard tune-up stuff in consideration as well. I don't think any greater than 15 mpg average is possible with all this involved, but maybe/hopefully I am wrong. I really want to reduce the clutter under the hood, and reduce the parasitic drag on the engine, but on the 3FE it appears the gain is minimum for the work/risk (50 state resale) involved. I guess if there was a significant mileage gain to be had I wouldn't be as wishy washy on this. Living in Virginia, and having a home of record as Mississippi, I could remove it all, but if I get orders to a more stringent state, I don't want any "issues".
Howdy! If you get orders to California or Arizona, you will have issues with the smog inspections. Anything more than an aftermarket muffler or air cleaner may get you dinged. John
I think that military personnel can keep their vehicle registered in their home State even while stationed in a different State. If that is in fact true, then the only issues are:
(1) desmogging without creating a face full of check engine lights.
(2) the home State not having an issue with your rig.
After posting this and dwelling on it for a while, I went out and did a visual inspection on the smog gear. Many of the small lines fell off at their connections as the hard lines had rusted. Apparently my system isn't running at it's optimal level. This is the deciding factor! I don't want to replace any of the factory smog stuff. I now have a plan, but executing it may take a while. It is going to be a multi stage tune and tweak. I do plan on recording the results. Ideally I would like to have the resources to have Dyno numbers, and true smog data, but it just isn't in my budget. Therefore I'll center my results on fuel mileage alone.
First I will just run it as is for a few tanks to get good average MPG.
Second will be a full tune-up. Again I'll run it for a few tanks and record the mileage to see if anything changes.
Third will be the de-smog as per the guide here. The only difference is I intend to keep everything physically in place but disabled, and disguised as functional. I'll remove the belt for the smog pump, as it can be reinstalled relatively easily for visual inspection. Again I'll record mileage.
Last I'll do a complete exhaust. Here I plan on running the stock sized down tubes, and 2.25" high flow cats. The y-pipe will enlarge the outlet to 2.50", and there will be a generic turbo muffler. I have somehow acquired a spare set of injectors, that I'll have balanced and installed at this time too. Again I'll record mileage.
Other than the exhaust this should be inexpensive except for the fuel. I know there are a few factors that may skew numbers. Tire size, and pressure, condition of the brakes, to name a few. I plan on doing this over the winter/spring, so the AC can be turned off and not as much of a factor. Are there any other easily controllable variables I should consider? I am also contemplating a MSD ignition. I run one on my FJ40, and like how it runs. Should it help anything on the 3FE?
Before I start this long drawn out project is there any input, or things I have obviously left out?
Now I have to discipline myself to logging the fuel mileage starting with the next tank.
I am pretty sure as long as I am Active Duty I have the option of registering the vehicle in my home state. Mississippi is pretty generic on vehicle inspections, pretty much lights, e-brake wipers and horn. My 40 has been for years, but after retirement, I think those rules change. Who knows how long I'll have this thing.
Diesel would be really cool, but not cost effective on initial cost. I think if any engine swap happens it will be a modern GM v8 of some sort. Don't get me wrong I do love diesels, but...
As long as you are Active Duty your only responsibility is to have a Current Registration for the State that your car is registered in and Proof of Insurance. Vehicle inspections are out the window.
