Ome steering stabilizer hardware
So I'm about to swap out my stock steering stabilizer with a used one stabilizer. The ome didn't come with hardware. Am I able to use just good old grade 8 nuts and bolts, or do I need to find the tapered shafts?
The OME hardware is not common hardware. It is also not the same as the OEM hardware was, so you can't simply interchange pieces.
Here is what my OME has, it came with the kit.
HTH
Had this same issue, called ARB & they're sending asap free of charge. Mud to the rescue again! Recommend purchasing from reputable vendors vs. amazon...
