OME Springs
S. Jersey - New Germany
I have a 2.5" suspension lift with OME 851 springs on the front and OME 860 springs on the rear. I've just added a Slee Short Bus Bumper with a Warn M8000 winch. Not only does the front of my truck feel heavier in the front it also is lower due to the added weight. There is only about an 1.25" difference in the wheel wells but my truck looks like it is much higher in the rear. I know my options are to either add a spacer or go to a heavier spring in the front. I'm guessing adding heavier springs will give me the better ride. Any thoughts?
I have an ARB with Warn 9000 and just put 850/860's on. I am very happy with the level ride and improved feel. Most folks would say the same. You should be able to sell your 851's to pay for part of the upgrade expense.
Does your rig still sit higher in the back with the 860s on the rear?
I didn't think of this before. Do I need to do anything with the caster correction or alignment if I go to 850 springs?
We are set up just about the same and I run 850/860. It is nearly level, and rides nice. I would sell off the 851's and get some 850's. I run Slee Blue's for caster correction and it drives great.
I just installed 850/860's and have an ARB front bumper (no winch yet) and the rear is about .4 inches higher than the front. The difference between 850's and 851's is about .8 inches so I would run the heavies (850's) with a bumper and winch. You can also use a spacer with your 851's as the spring rates are the same.
Check this out:
https://forum.ih8mud.com/80-series-tech/44674-dont-swap-med-heavy-oem-springs.html
Check this out:
That was a very interesting read. What I got out of it was the only thing that really changes is the quality of the ride staying within the limitations of raising the front back to the truck's original height. I'm assuming (hate when I do this) that my best option is to go to a heavier spring (850). I'm also thinking that bringing my front back to the same height when the lift and caster correction was installed should not need any other caster correction.
I'm running the normal OME castor correction and steering feels the same as stock. Also front might be a tad lower than rear but looks about the same angle as pre lift.
Seeing that we have almost the same set up would you add a spacer in addition to the 850 springs?
When through the same process myself. My ARB and winch lowered the front and I went with the Slee blue spacers. IMO the spacers improved the steering and almost leveled it out. This seemed less complicated than getting the new springs.
Just swapped out my 851 springs with 850s, definitely a big difference as well as a much nicer ride. Thanks for all the help mud. :flipoff2:
