OME Spring Identification, Aussie or Not?
Midwest
I just picked up a set of well used OME springs that have been painted so I can't identify them. The spring eye measures 35mm and judging by the spring count they are the med/light duty springs. My question is whether they are old enough to be Australian made springs, I believe the part number would be OME-13, or if they are of the newer CS001F/R variety? I think there may be some differences with the spring eye size or something along those lines. I don't see a metal sleeve in the eye and the bushings are wasted.
The reason being is that while I got a good deal on them, one front spring has been replaced with an imposter spring so I would like to hunt down the appropriate match.
Here is the best pics I have at the moment:
View attachment 1791482 View attachment 1791485 View attachment 1791482 View attachment 1791485
i brought new ome springs and they didn't come with metal bushings in them, in fact i have never seen metal inserts in a landcruiser spring. not much help but here are my new springs from old man emu. these were for a HJ47 so have the large pin sized bushings. i went heavy duty front and light/medium duty on the rears. hth
The problem I see with the yellow spring bushings is: (a) they are not graphite impregnated (built-in lubricant) because they are not black, and (b) they may not have the "Inhibitor" that lets them tolerate lubricants. Red Rancho bushing were this way, and if you greased them, they would absorb the grease, turn black'ish, turn soft'ish, then you could rub them away with your thumb nail.
Those springs look the same as my 4 year old springs except that my bushings go in from both sides.
I've been using those yellow OME bushings for around 4 years now without lubrication issues. I have tried both marine grease and anti-seize. Not sure the grease really helps other than at install time.
