OME sprigs 863 / 860
Finland
OME 860/863 height difference ?
What is the difference in height without load ?
I think that I have a 863 and I would like to drop the rear a little bit .
Does it make sense ?
860 & 863 both have the same free height.
From memory they are approx. 18.89". The spring rate of a 860 is 220lbs & the 863 is 250lbs. The 863 will generally will give approx 1" of ride height from the 860...
860 = 18.89"/19.23"
863 = 18.89"/19.23"
863J = 19.88"/20.27"
864 = 18.89"/19.23"
20151023_201106-1-jpg.1153603
Thanks.
Bar diameter is 18 mm. It's probably 863 what I have .
I have in front OME 850 and 10 mm. specers.
From hub to fender whithout load .
Front 58 mm.
Rear 60 mm.
Thanks.
Front 58 mm.
Rear 60 mm.
In the market for 850/863 or 850/860. So with that 10mm your nearly level unloaded? Any winch or bumpers?
850, spacer, 863 here. ARB front with a Warn M8000, 4X4Labs rear with swing out. Tools in the back, daily driver. Relatively level, but still has rake which is good. People tend to be obsessed with leveling their rigs, if you ever plan on carrying load the rake is a good thing.
