OME lift time
Scottsdale, Arizona
Can't leave well enough alone...Its all your guys' fault!:D All these nice rigs getting me wanting to keep tinkering! Anyway, I am looking into taking out the 1" coil spacers and going to a 2" coil lift. OME makes a selection of 10,40,50,75 mm springs in light, medium, heavy configurations in constant or variable rates (rear only). So........heres where I am hoping some folks out there can speak from experience and advise. I am thinking on running light front (OME851) and medium rear (OME860) both are 50mm springs and state a 2" lift (Gotta fit in the garage). I dont plan on any heavy additions to either end (ARB bumper/winch, etc):frown:, I drive mostly on road and tow only occasionly a lightish 2,000 lb trailer. I do have rear Air lift air bags but wonder if they will still be (as) effective with the longer springs? I definetly will also get the caster bushing correction kit to do it right. Looking for a nice ride and good off road performance. Anybody out there go down this road already?
I went with heavies front and rear and the only extra mod I have is a 50 pound speaker box in the rear and a TJM front bumper. The ride is still awesome too. Also, if you are upgrading from stock suspension you will net more like 2.5-3 inches of lift.
I have done the 851 and 860's I did not need to adjust the castor. It's great looks great and can handle any trail Im willing to drive a DD through with ease. The ride was much improved over the stock LX springs.
I had a thread with pictures some where here Ill look
I went with light front and rear. My duty is much like yours. Road mostly, occasional towing and trail use is only gravel/dirt roads. No heavy additions to either end. I like what I chose. Rig is level. I originally wanted to get medium rears but was talked out of it by the Slee phone rep.
I have two '96s with two different OME lifts. I like them both and they both serve different purposes.
Grey is 850/863 (Heavy 2.5") and has 285/75R16 MTR tires (33"), ARB bumper with warn M12k and Slee rear bumper with tire carrier and Hanna sliders and a 24 gal. aux tank. Even with all that weight it was too tall to fit in my garage...until I took the roof rack off. Now I have 1.75" to spare and am considering 36" tires. When fully loaded for the trail & camping it sits down and becomes level. Empty with the sub tank empty there is a bit of stinkbug, but not 'bad'. Expedition use build with emphasis on trails & camping.
Red was just done this last weekend. OME 861/862 (heavy no-lift) with -no- additional weight. Hard to tell its 'lifted' from a distance. I'm 6'2" and I can now stand straight up under the tailgate. I used to have to duck a bit. About 1.5" of lift. Stock tires now, but will eventually go to 33". Wife's truck / soccer mom mobile / grocery getter / Sunday go to church / on-road family trips. This truck has never been off road.
Both kits purchased from www.sleeoffroad.com. Watch out for those bottom shock bolts when taking the old stuff off. Start spraying them now.
I wouldn't do anything lighter than 850 (heavies) up front. I got exactly 2.5" of lif with 850's, and when my 70 lb quick-mount winch is plugged into my 50lb tube bumper, the front will sag a good .5" or more.
I also wouldn't do lighter than mediums in the rear. When my 70lb Boxer jumps out, the rear raises up a little!
Good info to chew on adn thanks for the thread CC - alot of good additional. I may call some of the suggested folks too. Appreciate the feedback!
Did you use any spacers in the front? Any stinkbug stand? Most people reported a slight stinkbug (0.5"-1") drop in the front.
No spacers. It has a touch of rake, but right now I don't think it is -bad-. I may change this judgement 2 months from now when the suspension has time to settle a touch.
my rig has a little stinkbugging effect, but i am cool with it. when i load it up with tools and stuff, it goes away. i will be putting some spacers on there when i get them ordered.
