Need help with OME low lift
Golden Colorado
I have done searches and I cannot find any thing on this. I dont want to do a 2 1/2". How much would I get with a OME low lift.
Any pictures, what parts do I need. Do I need to realign steering? Where is the best place to buy.
Thanks for any help
Check sleeoffroad they describe it all. I have searched this myself the and the info is there you just need to look.:flipoff2:
Enter keywords: ome low lift
In a nutshell, you will get ~1" around. You will need the 4 coils. You can use your existing shocks. You don't need to realign anything uless your steering wheel is off center when the wheels are straight, and then you adjust your drag link.
Thanks for any help
If you still have the original springs you will see some increase do to sag if nothing else. The low lift OME are just heavier sprung and should return the truck back to stock height. I think some have seen about an inch increase over where they started.
When I did mine, I got about 3/4" of lift, but more importantly, they fixed what I deem to be a problem with the stock 80, soft rear springs. Now I can put 6 passengers in the truck without worrying about bottoming it out. If you do them, you should also do shocks at the Same time, Bilsteins work perfectly with the low lift springs are a better shock than the OME shocks. Finally, you may have to do the caster bushings, as some trucks even stock have marginal castor and even a small lift can push them over the edge.
Cary
When I did mine, I got about 3/4" of lift, but more importantly, they fixed what I deem to be a problem with the stock 80, soft rear springs. Now I can put 6 passengers in the truck without worrying about bottoming it out. If you do them, you should also do shocks at the Same time, Bilsteins work perfectly with the low lift springs are a better shock than the OME shocks. Cary
x2 on the OME861/862 springs + Bilsteins.
Transformed the handling of my truck as I really didn't
want any significant lift.
Checkout www.sleeoffroad.com as well as the FAQ for info
I ordered my OME lift Kit from 4x4 Connection. Ask for Curtis, gave me plenty of advice. I did get 4 New Springs, 4 New Nitrogen Shocks and a Caster Correction Kit. Parts are sitting in the back of my LC waiting to get a chance for install.
No problem I will also post pictures of before and after. Im betting my rear will be around 2 - 3 inches as it just looks to be sagging BAD. I only have 104,000 miles but I know they are shot.
FWIW Slee has been great. I live about 45 minutes from them and on more than one ocassion a employee who lives very close to me has brought up parts to his house and let me come pick them up!
Hats off to Slee and especially Ben at Slee. If you live in Colorado or close try to support them.
Groovy. I'm thinking we're in similar boats... 97, LX with about 100k. I'm just looking for a little stance improvement/better load capacity, and although I don't mind adding the caster correction bushings if need be, I don't what to get in to all the driveline vibration issues.
:beer:
Rookie2
the absolutely most you would need is the OME yellow bushings and I don't see any problems with drive line vibs from those.
Are the OME yellow bushings a separate item and can they be also added with the lift kit? Also how much more clearance will they give you?
I put an OME low lift on my LX450 about 1.5 years ago. As others have noted, I got ~1" of lift. As Landtank and Cary have mentioned, you should check your caster - mine is below specs with this lift. I have the OME caster bushings and plan to install them when it warms up a tad and then I will remeasure to see what change I got.
Cheers, Hugh
PS, the busings are used to correct caster in the steering, not to give added lift (e.g., like spacers)
Well finished installing the springs this morning. Did the rear yesterday and the fronts today. Best advice is get some good sturdy tall jack stands and a couple of jacks. Follow instructions on slees web site and its a breeze
As far as driving its a huge difference, handles much better. I would think if your springs are original this is a must do
Here are before and after measurements from middle of axle to bottom of fender flare
Before After
D Front 19 5/8" 20 3/4"
P Front 19 3/4" 20 3/4"
D Rear 18 3/4" 21"
P Rear 18 1/2" 21"
As you can see this made a big difference in the lift
I like this a lot as it is my DD and I need it to be somewhat professional.
First picture is before
Second is after
Sorry for the ignorance...
Are castor correcting bushing required if you go with the OME stock height kit using 861/862 springs & N73/N74E shocks or OME springs & Bilsteins? How do you know if you need the bushings?
Cary, I will search again for the Bilstein #s, but if you remember them off the top of your head...
Thanks,
Riley
edit: Found it: Front Shock is B46-1477 $59.99 per shock / Rear is B46-1478 $59.99 per shock
Now just the caster question...
No, you don't need the castor correction bushings with the low-lift springs (861/862). Generally at 2.5" and above you'll need some castor correction.
Actually, according to Christo, even stock height trucks can have caster issues. It is totally truck dependent. I know that I need to put in the caster bushing with my low lift springs, the truck clearly has less caster than needed.
