Warning:
Long and rambling thoughts about a potpourri of OME springs.
Pondering new coils and lifts in the 3 to 4 range.
This is just a consideration of OME coils right now, so please hold-off on the Slee/FOR recommendations
Currently running 850/863 with 15mm trim packers front and rear.
My static (without extra loads of stuff for long trips) rake is only 2.5" front to 3.0 inches in the rear.
Straight-up J's all around would keep all things the same and add about and inch to my current lift.
But a little extra support might be nice as well. My current ride is nice and squishy off road when loaded up, but it's really squishy.
The OME Comp springs bump from 220 lbf/inch up front to 300, and from 250 lbf/inch out back to 280. The Comp springs come in various heights.
The 864 for the rear are the same free height as the 863's, but they have a rate of 320 lbf/inch. Running these would effective give the same static height as the 863Js but me much stiffer.
I've run a whole bunch of numbers with mixes and matches of all of the above springs, and I won't repeat them here (unless somebody wants them). There are at least 5 or six combinations that would get me between 3.5 and 4.5 inches of lift. The questions is, what would be the best arrangement in terms of spring rate front vs. rear and lift?
Example:
1.
418 Comps at 300 lbf/in front with 864 at 320 lbf/in rear. That gives me a level truck at static load, a firm ride up front, and a downright burly ride in back, but with huge load capacity. Dan?
The static lift should be about 4.25 inches.
2.
850J at 220 lbf/in up front with 421 Comps at 280 lbf/in in the rear. Again, level truck, with extra load capacity out back, but overall softer than #1, above.
This lift should come to about 3.7 inches.
Thoughts?
Example:
1.
2.
Thoughts?
