Ome 850/864
OKC
I'm getting 850's on the front and 864's on the rear put on my
94 right now. Anyone have this same setup or similar? If you decided to add spring spacers or wheel spacers, please post why and how you like the results. Pics would be awesome. I'm wondering if I should have insisted on 850J's in the front. I am getting the ARB bar with 9.5 XP warn winch installed after the lift and an iron pig rear installed as well. My tires are 33x12.5x16.
If you don't get a 1" spacer for the front or exchange the 850's for 850J's, you might be ass end high with the heavy winch and front bumper, unless you fill the back with cargo such as recovery gear, tools, etc, 100% of the time, even with the IPOR bumper.
Plenty of thread with usefull info ..
I would prefeer 850J front and your selection rear .. but I thought you already know that those coils for the rear are suposed for heavy ( said heavy ) constant load ..
OME 850's w SLEE 1" spacer and 864's outback with MAF 1" spacer. Tire size is a 295/75R16.
I also, have 2 spares on the kaymar bumper, outback drawers fully loaded and a aux tank. Plus the trailer. Our rig is setup stinkbug unloaded and like above when fully loaded. Rides like a caddy and works perfect for us. Our rig isn't light at all.
You will have serious stinkbug without a spacer in the front or alot of cargo.
That's what I am thinking too but ARB's PDF says that the 863's will give you 2 inches of lift while the 864's will only give 1.5". Hmmm.
Thanks to all for the pics so far. If anyone has a pic of an unloaded 850/864, I'd like to see if it's stankbug or not. Thanks.
I hope to make a twin of your ride someday! Awesome website too!
I don't have any before spacer shots, but here is 1.5" front spacer with the 850/864 combo.
No extra load like bumpers or what not.
Unless I am fully loaded, it rides like an empty pickup truck. And by fully loaded, I mean to the roof. I couldn't detect any real difference in height after the 4x4Labs bumper.
I like them when I am fully loaded, less so when empty. I have put 550sqft of tile back there at one point too. :hillbilly: Not something I would recommend to anyone.
Perfect. Exactly what I was hoping to see and same color as mine too. Where did you buy your spacers at and did you have to do any modification to the front brake lines or anything else?
but it is only a 850/863 (what's a 864?)
Lance the 864 it's the real HD coil for the rear with 320 lbf/in spring rate compared to 250 lbf/in for the 863 coil .. both share the exact same dimesions and number of coils ..
Ah, thanks. I think the 863's are good enough for me (for now ;))
-Lance
Which kind of CC bushings do you install? Slee or OME? Your truck's height looks very good to me.
OME bushings. No driveline noise.
My cross caster numbers are just barely within specs.
I have this combo and was @ss high as stated above. Added Slee's 1" spacers this weekend. Its better but not where I want it. Even with adding the rear bumper and throwing a rear tire in the rear I don't see it coming down much. I may look to put metaltech's 1.5 spacer in place of the Slee spacers. I own couple 40's so I'm new to 80's and read numerous posts which were all helpful but from reading its all how you load the front and rear which will decide your spring set and you can reach a point where if you go to far you run into caster correction, driveline vibration worries among numerous other goodies you'll need to get it right. I'm sure I'm not telling you anything you don't know just trying to help. I'm sure the experts will help. I'll be looking to see how your install goes.
ARB up front no winch yet.
No rear bumper yet, spare tire and mount gone.
Before
After
