OME 3" kit
San Juan Puerto Rico
Website
www.facebook.com
I like my OME lift personally. Bang for buck :). There is better ones out there IMO, but cost a lot more. Keep in mind the OME heavies were designed to be install on heavy weighted truck ei: winches, bumpers, armor, etc.
The suspension is good!!! I installed it about a month ago and no complaints about it except that it rides higher on the rear (about 1.5"). My total lift was about 3.5" in the front and almost 5" in the rear. My 80 have no additional weight on the front and on the rear I removed the spare tire, rear bumper, and 3rd row seat so that could be the reason that the rear sits so high. I would recomend you to add a 1" spacer in the front (I did it and looks good) or go with the OME competition front springs. As an extra for best performance, you will need to buy or fabricate lowering mounts/spacers for the rear height sensing proportioning valve, sway bars, parking brake cable, bump stops, and brake lines. For caster correction I can not help you much, I have done nothing to mine yet. I have the OME caster correction bushings but they will not solve the caster problem completely (I would guess it will improve about 50-60% but it depends on each vehicle) so I'm looking into lowering radius arm brakets or caster plates.
Hope that helps!
Saludos.
I'm thinking on getting the spacers first. If I get them for the front will they level the vehicle?:hhmm:
My truck is getting a HEAVY duty bumper fabricated, most likely a winch also.:)
you'll probably need much more than what that kit provides to set the truck up properly.
that is true. i've had to add on a couple of stuff since i've bought the kit. bumpstops, brakelines, drop brackets, looking to buy DC driveshaft, and working my way to the panhard rods
not entirely but it would make it look WAY better
Probably that 1 inch of lift will be enough to clear for my 33's, I went off road yesterday, nothing extreme and the tires did not rub, except on tight turns.:hhmm:
I Love mine. Its made all the difference. Like landtank said you will need alot more. Ask me how I know....
Check my sig for setup.
How do these things go together. You have 3.5" of lift, most probably 0 or negative caster, yet the suspension is good? Looks good? Handle good? (I doubt it)
Like Rick said, there is more to it than what is listed, suggesting doing that suspension and adding additional spacers up front makes it even worse.
I've always been confused by the Emu 3-inch lift on MAFs site. Slee sells the 2.5 kit, and mudders seem to like this option because it is the "simple" lift that avoids drivetrain corrections and allows for HD coils and 35 inch tires. Seems like this kit is a better value. Once you exceed the 2.5, you are looking at a more complex install to do it right, and there seem to be better options than Emu.
I have the Emu stock height coils and have outgrown them, so I've been looking at the 2.5 inch HD since I'll be adding a rear bumper/spare and want to go to 315s.
you can clear those 33s without the lift! the 3" OME lift and 33s don't match IMO. 35s look better.
x2 on the caster. installed the blue bushings and it sure was a BIG improvement. i didn't like the handling with the yellow bushings.
Yes the suspension is "good" and I do not recall saying anything about how it handled without caster correction. It looks good with the spacer in the front, rides good (bump absorbtion, stiffnes), and handling (steering feel) is not good because I have done nothing to correct caster but the same thing will happend with any suspension if you don't correct it to factory specs. I think for the money this suspension is "good", you will have to add MORE things to make it work at its 100% (as I said previously) but it is a good "kit" to start with.
Hey Jose, Like discussed in your thread about new meats, I think the issue with your rubbing is the 15" steelies you are running. A lift may help there, but I really dont know. I ran 33's with out with zero issues. I lift and like the ride and the 33's look good on it. Just my .02
I readjusted the steering stop bolts an now is not rubbing, but the tires are pretty close to the rear of the front bumper. I'm going to try the poly spacers in the front and see what happens.:hhmm:
