OM 613 3.2 CDI swap into 80FZJ
Just to update this week we began to speed the process up. The situation is little changed. We are going to drop the engine not in my truck but the test one which had several different engines in the past. It is due of we would like to commercialize the product.
Thus I am gauging the interest of people on OM 613/648 ECM + manual/auto flywheel flexplate to H151F/A343 + adapter. And list of what else needs to be installed as we think it is easy to source simple things locally.
How much we should sell these products as the kits?
In one month, maximum two we will bring the truck out. After tests kit will be available.
I'd recommend posting in the diesel cruisers section if you haven't already. People might be interested in this for 60 or even 40 series trucks
Progressing.....
The adapter plate is for use with which gearbox ?
H151F manual. We will be making the torque plate for auto as well.
There is the little problem with auto. We have not figured out how to conjunct OM's brains with Toyota's auto's brains. We are working on it :)
What transmission did the OM613 come with originally? I would assume that the Mercedes 722.6 transmission would be a direct fit. Those are very strong and can run with a simple stand-alone controller.
Have no idea. As we want to use the Toy's manual we never even considered using auto. And when we will be looking for auto we will be looking for Toyota's AF trans as we want to keep as stock as possible.
ahoj Tugarin. môžete požiadať o pomoc od svojho Nissan Patrol, ktoré som 3.2CDI motor om 613th
Я не могу найти тот Патрол он где то в селе ездит. Я его видел два раза один раз когда его собирали второй когда он уже ездил. Но сейчас один товарищ ставит OM613 в Патруля автомат и есть еще один Патруль который уже проходит тестовые заезды с ОМ648 спорошу информацию и постараюсь получить фото и видео.
[Citáciám = "Tugarin, PO: 10926493, Pomocník člen: 61576"] Я не могу найти тот Патрол он где то в селе ездит. Я его видел два раза один раз когда его собирали второй когда он уже ездил. Но сейчас один товарищ ставит OM613 в Патруля автомат и есть еще один Патруль который уже проходит тестовые заезды с ОМ648 спорошу информацию и постараюсь получить фото и видео. [/ Citáciám]
[Quote = "Tugarin, po: 10926493, člen: 61576"] Я не могу найти тот Патрол он где то в селе ездит. Я его видел два раза один раз когда его собирали второй когда он уже ездил. Но сейчас один товарищ ставит OM613 в Патруля автомат и есть еще один Патруль который уже проходит тестовые заезды с ОМ648 спорошу информацию и постараюсь получить фото и видео. [/ Quote]
Я должен был бы модифицированный ECU, потому что есть ручной prevodovka.Chcem заставить его работать без приборной панели .Это можно?
Я должен был бы модифицированный ECU, потому что есть ручной prevodovka.Chcem заставить его работать без приборной панели .Это можно ??
Budem mať upravenú ECU, pretože tam je manuálne prevodovka.Chcem dostať do práce, bez toho aby na palubnú dosku .To môže ?? [/ quote]
Máte e-mail?
А они обязательно будут модифицированные, прямо родной ЭБУ не будет работать. Это будет ЭБУ который перепрошит и адаптирован под работу с приборной доской Ленд Крузера. Приборной доске нужны только сигналы от ЭБУ или напрямуб от датчиков. В нашем случае с ТЛК нужны только сигналы доска сама не генерирует сигналы. Это делается если завязана штатня проводка.
