- Thread starter
- #41
tarbe said:Did you stuff the opposite side? If not, you may well not have achieved max droop. Unless you are certain you maxed the shock.
It is pretty tough to simulate max articulation in the garage with a floor jack.
no, I jacked up the side closest to the driveshaft, so the other side was indeed likely not fully stuffed. The shock was out to the point that the upper end of the thick lower part of the body was just even with the lowe part of the upper "cap". Likely all out since the wheel was off the ground. I don't think it would make more than 1/2" difference or so
