e9999 said:I guess, folks, what I'm really asking is what is the minimum amount of mods one could reasonably get away with if one would want a 2.5" or Js?
Or IOW, can one get away with just putting heavies -or better Js- springs and do nothing else?
Beowulf said:I could argue that expedition wheeling requires just as much suspension flex as rock crawling. You wouldn't want to be 1 ravine away from that prime camping spot and discover that you can't cross it and have to end the "expedition" early.
-B-
tarbe said:I would be skeptical of any absolutely definitive statements such as "You never have to..."
I can tell you that with nothing more than an OME heavy lift I was carving the slip yoke cover on the sway bar. I HAD to drop my front sway bar. I do not have the L shocks.
e9999 said:I guess that's one data point that contradicts Beo's take on this then...
Cruiserdrew said:I would argue a bit differently.
Beowulf said:Eric,
Reread my post and his post. He said OME heavy lift. I'll bet a case of Keystone that included OME shocks which are LONGER than stock. My post specifies STOCK length shocks.
I would be shocked (pun intended) if he was hitting the driveshaft with stock shocks and any of the OME springs.
-B-
Beowulf said:Eric,
-B-
e9999 said:good point.
I went out and measured the gap. Lifted the truck to let the wheel droop fully with stock shocks (the limiting factor I assume). I got 1 3/4" gap between the sway bar and the driveshaft. IIRC, the OME shocks are just about 2" or so longer, so yes, that would bridge the gap and make it hit or be too close.
NorCalDoug said:Eric - you've ridden in my rig. All I have on mine suspension wise is the OME 2.5 and the OME shocks that go with them. You'll likely want to install the castor correction kit and drop the LPSV. That's it.
