Ok need help!!!
That’s what I was thinking, but was talked out of buying a new battery by both places!!! The battery test showed 760 CA on a 730 CA batter????
Well it’s true, “Time heals all wounds” remote started the truck, everything is working as it should?!?!? Yesterday was a crazy day....thanks again for everyones input....this site is great!!
Replace the battery as a precaution and the truck died yesterday and is dead again this morning.... thus can’t be good!
1-did you check all your fuses as recommended above? If not do that first. As stated, jump starting can fry a CCM or pop a fuse. Since that was the diagnostic code pulled, check that first. A damaged/shorted CCM could cause a parasitic drain. Since you have a drain, a blown fuse is unlikely, but possible.
2-clean your battery terminals and charge battery.
3-check current drain on the battery by measuring Amps with a suitable meter.
Disconnect one side of the battery and put an Ammeter in line between the terminal and disconnected cable note: do not start the car with this meter connected as this could fry your meter. Pull fuses and test again. Put fuse back in and pull next...repeat until a large draw disappears. Then see what that fuse connects to and troubleshoot down from there. Good luck.
Well this is interesting, got home truck has been dead for 24 hours and this relay was clicking so loud you could hear it hear in the garage, it was under the hood in the fuse fuse box. Pulled it started the truck drove for 5 miles only thing not working were the vanity and over head lights???
Thanks for the photo. Looks like you did a recent brake fluid flush as well. Fluid looks clean.
A bad jump start (hooked up wrong, fault in battery pack or jumping vehicle) can definitely fry a starter relay...
The truck was dead on Monday and had never been jump started before so, it died on its own.....absolutely never hooked up wrong and the battery pack is top of the line.
