Oil weights/types
Hello,
I'm finalizing a deal on a 94' Cruiser tomorrow and am already making out my list of to-do's. This cruiser has 178k miles on it, but only 112k on the motor. It was replaced by Toyota under warranty and it runs very smooth. I do most of my own work, if I can fit it into my schedule. I was curious about oil weights and types. Are there too many miles on this engine to consider switching to synthetic? Is synthetic even a good idea for this engine?
What oil weights are you guys running? I'm in Atlanta so our summers get pretty warm and usually our winters are mild, but we have seen a lot of "teens" recently so it will get cold in the winter.
I checked the search and unless I'm not doing it right I couldn't find much out there on this topic. I look forward to hearing what you guys are doing. I will post up pics and info about my new LC when I get it tomorrow. It's pretty sweet!
Thanks,
Chris
Welcome to mud.
Here is the FAQ's info on OIL
There is a lot of good info there and its a good idea to familiarize yourself with it for maintenance on a new to you rig.
Congrats on the purchase.
Im running 0w40 Mobil 1.
Hello,
Thanks,
Chris
I use 10W30 extended protection synthetic Mobil oil for Mid Atlantic area. For your motor with that miles, maybe you can use the Mobil synthetic high mileage oil.
15w-40 for the warm months, 10w-40 for the cold. But we don't get very cold very often (almost never under 20*).
If you're in the teens you can run 0w-40 or 5w-40.
Thanks guys, not sure why I didn't find that link as I have been reading the FAQ's for a couple of days now.
thanks,
Chris
I live in Anniston, AL which is pretty close to atl. I use Mobil 1 10w40 high mileage year round with great results. I go 5k in a change and it uses absolutely no oil.
Per FSM for our temp range I use castrol gtx 10w-30 i live in augusta. I think the info is in the owners manual. Synthetic costs alot more and i change mine often. Sams club is cheap if ya get the 5 quart jugs. Make sure you use toyota filters
I run Mobil 1 15W50 (red cap). Good additive package in the oil. Thermal stability is tough to beat. It flows better than any conventional 5W oil at low temps. Starts fine in 25 below weather. Protects well againts heat.
15W-50 isn't too heavy? I used to run that in my M3 on the track, but rarely around town as it seemed like overkill.
Not at all. The viscosity is high (which relates to higher load capability or resistance to shear) but being synthetic makes it flow very well at cold temps. Being a 15W oil, it doesn't have to comply with the energy ratings like 5W and 10W oils do. This means mobil can put the good additives in it. The additives help seal wear in cylinder walls, prevent oxidation, etc. This is typically the difference between regular and high mileage oils.
BTW, I drive an 80 because I prefer overkill :)
