oil sludge
Arkansas
I adjusted the valves on my '92 Land Cruiser today. When I removed the valve cover I was amazed at how much oil sludge (1/8") was in the top of the engine. I just purchased this truck 3 weeks ago and the previous owner had changed the oil every 5000 miles using Mobile 1, but only had the truck for about 18 months so I have no idea about the maintenance prior to that. It shows 109,000 miles. Is there any way to remove this sludge? I was thinking about possibly using some kind of solvent from a spray bottle and a nylon bristle brush and also removing the oil pan, but thought I better check on here first. Any help would be greatly appreciated. Thanks!!
Start with a plastic scrapper to get the bulk of it off and then I use simple green to clean a lot of parts and have had good luck with that. But an engine degreaser would work as well.
Evidently the Owner prior the guy that sold it to you used some crappy oil. Citrus degreaser will work for the valve cover, as for the head and valves, I have seen old timers brushing diesel with a stiff brush. After cleaning the head, an oil change is a must. :steer:
1992? I've been told that this is normal with the F engines (F, 2F, 3FE).
I can see some build-up in mine when I take the oil cap off, but it runs great. Oil changes every 3,000 with Valvoline 20W-50.
:meh:
We've only put about 500 miles on it since we've bought it and it seems to run great. It just sounded like a diesel engine when it was running and it sounds much better since the valve adjustment today. The previous owner said that it did not use oil, that it would be approx. a pint low at his 5,000 mile oil change. The valve cover gasket is leaking so I am going to have to pull the cover off again to replace that. The gunk that is in there scr apes off easily. It seems like it would probably easily dissolve in diesel or kerosene. Do you think it would be necessary to pull the oil pan off or just spray and brush the valve train and drain it all out the bottom and maybe fill with the cheap oil and filter and start and then immediately drain again?
Correct, the earlier push rod motors circulate little oil to the head when compared to overhead cam motors, so tend to build debris. IMHO as long as it's staying in place it's not going to hurt anything. The danger is if it's dislodged, it could plug up the oil pickup screen.
So cleanup is an issue, if you decide to mechanically remove it, be sure that you get all of it out that you loosen. I wouldn't worry about it, if anything do a couple of short oil changes with cheap oil. Run it for a couple of thousand miles, add some engine flush, drain, fill with cheap oil then change again in ~2K miles to get what ever was loosened.
The best bet is probably just to run some "high mileage motor" type oil and do a few short changes ~3K miles, this will slowly clean it up.
I'm nervous about running oil flushes, it could dislodge a clump of sludge that could plug thing up. I prefer running a high-detergent oil like Mobil1 or Shell Rotella T Synthetic to gradually clean the gunk. It'll clean out the high-flow areas fastest, valve covers take a long time. I'd scrape and wipe the valve covers clean if you've got them off, and scrape out the heads where you can reach. Running a cheap oil and changing it very soon seems prudent afterward.
