HI From Cambodia,
I have a problem with my oil PSI, It will go to 0 or nothing at idle in gear some times but when driving it run at the H mark Im worred about it going to nothing at idle in gear water temp 200. air temp 95f or so.
Things I did to fix so far that done nothing ; I changed the oil to 20/w50 changed the filter not OEM toyota, new oil PSI sender. I do not get any noise like no oil PSI yet when it goes to 0. The motor seems to run fine lot power no bearings noise at start up.
Where can I look next? Could the Presser regulater be the problem? Does it have one? Oil Filter?
Why running at 60 mph its toped out at H and nothing at idle?
I seems to come and go ?
Need help before it blows up.
thanks
Brian
thanks
Brian
job
