oil pressure ?
Bozeman, MT
Have a little issue with the oil pressure I've asked about it before and thought I had an answer but I didn't so I'll ask again and try and hash it out a second time. My oil pressure is quite high, about 50 when first firing up and then after running for a bit and warming up usually sits about 20-25. Put on a new oil pressure regulator didn't make any difference. Went to a lighter weight oil didn't make any difference. Now I'm just looking for any more suggestions of things to try.
Things to try? Do you want to get a lower initial reading, or a higher warm reading?
Really, those numbers are not bad, and not unusual. F engines are HVLP; high volume, low pressure. The numbers on my F145/155 hybrid are virtually identical, and have been that way for a good 30k so far.
Hth
Mark A.
50 PSI is not high.
20-25 is a little low (I assume that is a warm idle reading... if it is at higher RPM is is very low).
I have one engine that I have massaged a bit. Amoung other mods I increased the output of the pump and installed an F engine style external, adjustable oil pressure regulator. I see 75-80 psi initial cold idle, warm idle of about 45-50 and 2500 warm is about 70.
If I kick the rpm up in the first minute or so of runn time on a real cold engine I can max out the oil pressure gauge (100psi). But this is not a good thing. I exploded a couple of oil filters during initial testing and tuning. :(
Mark...
I'm laughing reading this this morning. Last time I asked about it I was told that it was high and that once it warmed up and idled it should be about 14, so I thought I was like 10psi high warmed up. Good to know I have been worried for nothing. Thanks.:beer:
