Oil Pressure
Austin Texas
Replaced the distributor on my bosses cruiser. I had oil pressure for a few seconds and then lost it. Obviously it's not a coincidence that I replace one thing and loose another. So I'm wondering where to start on this thing to see what happened. It's a 1970 FJ40 land cruiser with a 236? Couldn't tell you too much more about it we just got this thing.
You likely knocked the wire off the sensor. Look at side of block for a round thing about the size of a half dollar. A wire hooks to it.
Wire is attached to the sending unit checked that and cleaned the contact point. I can hear valve train noise pretty bad and I've got no pressure on my aftermarket gauge
You have to have the distributor all they way seated or the oil pump won’t run and it will blow the motor up. The tip of the distributor goes in the oil pump and it turns it.
I know that much. Thankfully it's not my first rodeo. The thing is the distributor caught the gear perfectly fine. And then slip past a little bit more and I figured it must have met with the oil pump.
Take distributor out look in the hole with a light, you will see a slot for the tip of distributor to go in, that’s the oil pump. You can move that slot with a flat head screw driver. Takes a few times of adjusting it to get it all lined up.
I usually point the rotor at the #4 spark plug and line the oil pump slot up then drop it in.
At this point you need to prime the top end with oil before starting again. You can take a long screw driver cut it off and insert it in a drill and spin the oil pump this way to get oil back into the drivetrain.
I'll do that first thing in the morning. I take it the rotation in the pump is going to be clockwise when I prime it?
You will always get spark, you won't always get oil pressure.
Using a mirror, and a flashlight, note where the distributor is relative to its installed depth on the block, it is a good photo opportunity. Then remove the distributor, and prime the oil pump until oil comes out of the rocker assembly with the valve cover off. Rotate the crank with the priming so that the bearings get fresh oil spread around, particularly if you ran the engine for any time without oil pressure.
To complete the distributor installation, rotate the engine crankshaft so that the timing mark (ball bearing) on the flywheel appears lined up with the pointer in the inspection window (on the bellhousing). If the valve rockers have clearance for cylinder #1 then you are at cylinder #1 Before Top Dead Center; if they don't, then rotate the crank 360 degrees, then check for rocker clearance. Position the distributor rotor so that it is aligned with the #1 spark plug segment in the distributor cap. Turn the oil pump slot with your priming tool so that it can line up with the tang on the bottom of the distributor shaft, in that position. Then turn the distributor rotor 30 degrees counter-clockwise, and insert the distributor, having the clamp loose on the side of the block. As you insert the distributor housing, the distributor rotor will turn 30 degrees clockwise as the camshaft gear remains stationary, (it is helical). When I did the install for an OEM distributor, I noticed the installed depth, looked like this (below). If it doesn't, you probably missed the distributor shaft with the oil pump. Refer back to the observed installation depth before you took out the distributor to confirm that it is further in than it was before. It takes me several tries to get it just right. Then secure the distributor clamp on the distributor, and on the engine block, it is often recommended to replace the clamp with a new one, particularly if it is hanging up on the distributor housing from being over tightened.
