Oil pressure switch
Los Angeles
Ok, am I correct in thinking I have to remove the exhaust manifold to replace the oil pressure switch?
Thats how it appears in the FSM. :(
How big are you're hands?
Open the hood and take a look. I was able to take mine off without pulling the manifolds.
The oil pressure switch or the sender? The sender is easy to remove, 2 wires and spin it out. You can see it from underneath the truck..are you reading the FSM correctly?
Probably the sending unit. Oil pressure gauge is at zero. Truck is running fine.
You should easily be able to get at the sending unit without removing anything other than the heat shields on the exhaust manifolds...and I only remove those so I can see the unit better. I would check the wires and connectors going to the sending unit first. They can work loose, become corroded or get oil soaked. The sending units don't go out very often.
I've seen wires to the sending unit (2 wires) fall off, rust off and break off. They also break further up in the harness.
I think thats what has happened. (fell off) I looked this morning and the connection tab is bare. Wire has come off. I'll get in there tonight and find it (i hope) Hahaha
Remember there is a rectangle female end on the wire for ground and the other wire has a provision to be pushed on the round dimple on the sending unit.
Correct,.... and the ground wire is the one that usually falls off or becomes loose. Here is a pic of the wiring arrangement. (disregard the location of the sending unit, I relocated mine).
