So I had a pretty nasty oil leak that I determined was coming from my valve cover gasket and oil pump seal. Before doing he work I pressure washed most the residue. After doing this it ran like crap because water may have gotten in the intake. that is gone now. Changed the valve cover gasket and the spark plugs and did an oil change. All is well except my oil pressure gauge is not registering anything. No movement at all. Runs great minus that.
My thoughts are the actual sensor switch located on the driver side just above the oil pan or the harness for it. Is there a special socket for the sensor? Is there any problems for running without the oil pressure registering?
Thanks in advance for any help.
