Oil pressure sending unit
Oklahoma
I recently installed a new set of autometer gages. I had to do some fab to get the fuel sending unit to mount to the existing TLC fuel plate, but I got it working. The gages came with all sending units, but the oil pressure sending unit they sent me will not fit due to clearance issues on my 350. Is there a way to extend or modify an oil sending unit so it will fit. The one that was on the engine isn't calibrated the same so it just pegs out when I start it. How do I find out what resistance levels the new sending unit is?
Zac
Have a pic of your issue?
Been to Autometers site?
They typically have the tech info on their insturments out there....just may have to dig a bit...
http://www.autometer.com/
I have used a hose to the block sending unit port, routed to a 'T' fitting to get the Toyota sender, a mechanical gauge tube and a hour meter switch to all be in the oil pressure circut....
Good luck!
-Steve
Like Steve said, the solution is usually just plumbing. The fittings are typically 1/8 inch NPT (national pipe thread) that you can get at any hardware store, so you should be able to find some combination of elbows, Ts and pipe to move the sender out of the way.
