oil pressure gauge
CANADA
when driving etc my oil gauge max's out on the high end but basically when going above 60kph, dipstick reads perfect, not leaking anywhere. just had an oil change etc they used 5w30, wondering what u guys think it is, is it the oil they use?
Is the 80 new to you or is this a change in the stock gauge's behavior from previous observations?
I ask because from threads I read asking about oil pressure "concerns", it seems the oil pressure gauge on most 80s is anything but consistent. My gauge for instance reads just below the 2/3 mark when driving and just above the 1/3 mark at idle. This is with running both M1 0W/40 and Rotella 5W/40 (IIRC).
EDIT: Corrected my info above after actually watching my gauge tonight instead of trying to remember :)
its right on the full line on the dipstick. and the cruiser is new to me,
so u guys think its the gauge?, or oil or what else could it be?
If it is maxed out all of the time, I would guess it’s a gauge, sender, wiring problem. If it comes down after the motor warms up, my guess would be a stuck oil pressure relief valve. Confirm it by hooking up a temporary mechanical oil pressure gauge. IIRC the relief valve should open at ~70 psi, if the oil pressure reads higher than that the valve is stuck.
thanks
