Oil pressure gauge
For the life of me i can't find how this is suppose to go.
I've searched and searched but i can't find. I have the wire in the engine compartment but can't see how it attatches to the sensor.
Pictures would be awesome!
thanks,
By your sig. line you have a later 2F in a ' 70 config.?
I am running a 69 with a 2F out of a 77. I used the stock in-dash gauge, but had to extend the wire so that it reached the other side of the engine toward the front. The wire has a connector that slips onto the end of the sensor.
That's why it didn't make sense to me. Mine is missing the clip.
I believe is a 79 2f.
thanks for the help
I used a simple female spade connector since the stock connector was beat up. I had to pry the female spade connector a bit but it has worked great since I installed it. The connectors are available a Radio Shack.
Good luck!
Here is where it attaches. Drivers side of engine toward the rear right next to the block drain.
