oil pan bolt torque...
Bend, Oregon
Maybe someone reading this can help...
I have tried searching and checked out the FAQ section and can't find out what sort of torque setting to crank the oil pan bolts down. Anyone? I just changed out the oil pan gasket, rear main seal, etc. and want to make sure I don't screw it up. Thanks.
I tighten them so that the cork just starts to bulge at the edge.
7 ft/lbs. I have a writeup in the tech section if you need it. Start in the center and work out in a circular pattern, like a head gasket.
I found Steve's post here to be quite useful. Not too tight is the key.
Thanks for the link IDave. I had stumbled across that post a week or so before I ripped into this step of the project and it helped my a bunch. I used most of his suggestions and replacing the actual gasket and oil pan was a breeze. A very good read indeed...
