What does it mean when 1 spark plug has oil around the washer but all the others are perfectly dry? Does this mean the head is not sealing right and may be burning oil?
There is a seal in the bottom of the tube which keeps the oil inside the valve cover from getting into the tube. The valve cover will need to come off and all six tbe seals need to be replaced. You can also clean ot the throttle body at the same time. job. Search valve cover gasket replacement.
No, the oil will stay above the combustion chamber if the tube seal is leaking, the only way it will burn oil is if the valve guide seals or piston rings are letting oil past.
