Hi all,
This weekend I did a quick sniff test, and found that my HC's were super high, up at 1722 levels, my C0 level was low at .27, O2 at 20.7. So I drove it home and recalibrated the air to fuel ratio and checked my vacuum (no leaks). After getting it dialed in, I wanted to run compression numbers and found oil on plug #5.
Here are the compression numbers:
1. 151
2. 150
3. 149
4.150
5.149
6. 152
I have noticed white smoke on startup, but it mostly dissipates with time. No blue smoke. It has historically thrown smoke if I apply throttle, but normally white. It has been fairly stinky, but seemed to improve after redoing the fuel to air ratio.
I also recently adjusted my valves & set timing.
FJ40 - 4/1977. I do have a DUI distributor. I'm currently desmogged.
So a couple of questions...
How concerned should I be about the oil on the spark plug?
How should I proceed?
Is it ok to drive?
1. 151
2. 150
3. 149
4.150
5.149
6. 152
Is it ok to drive?
