Oil light, oil level question
Santa Cruz Mountains, CA
1996 with 127k miles, did an oil change less than 1000 miles ago with Mobil 1 synthetic. The other day about 1 to 2 minutes after starting it, the oil light came on. Turned it off and checked the level. It showed that it was a bit low, about the bottom of the hash marks on the dipstick. Turned it back on and the light never came back on. Checked the level the next day and it looks normal. Any ideas?
Trust the dipstick. The light is notoriously inaccurate. When my dipstick is below the halfway point on the hash marks when cold, the oil light will come on briefly a few minutes after starting. Experience has told me to plan on topping off in the near future.
The dipstick measures the oil level in the pan and will vary a bit if the motor has been running vs cold or due the angle of the ground your sitting on. If you're in the hash marks, you're good to go until you lose some oil.
FWIW, the fill line on the dipstick means you are roughly 2 quarts low from the 7.8 quart capacity. Unfortunately, I'm burning / leaking enough oil to frequently confirm this. At this point, I get an oil light about 5 minutes to running the engine, it stays on for about 20 seconds(ish) then goes out.
Agree, I usually fill with 8 qts when changing oil. It puts me at the full line on the dipstick. When I'm at the low line, a quart puts me in the middle and two would put me back at the top.
I'm actually having a similar issue with the oil level light that I never used to have. Once the oil level is below 3/4 mark on the dipstick the light will come on 1-2 mins into driving until the engine is fully warmed up.
I know it isn't the most accurate, but it can still be scary given that I'm driving a leaker. I'm wondering if there is any sort of adjustment for the oil level sensor or something easier than trying to replace it.
I'll be doing some major engine work soon, so that may be the ideal time to go in there and to go a fixin
I've noticed this too. But I believe the only thing happening is that after an overnight sit, the oil drains from the motor and collects int he pan. Upon start up, the engine has to 'prime' back up to normal oil levels. This leaves a little time where the oil level drops enough to signal 'low oil level' until the oil begins to run back into the pan. Then the light goes back off.
For me, using the smaller Toyota ZZD filters seemed to reduce the instances of the low level indication to a point where only now its illumination warrants taking a look.
It’s very easy to pull the oil level sensor and test it. The two I’ve looked at both had a fair amount of oil residue/gunk accumulated on them. Perhaps yours is to the point that it’s not letting the float move freely. It won’t hurt to check it and it would also give you an opportunity to replace the gasket which eventually leaks.
