A simple one bannana fix-
Pic#1- I noticed the oil level sensor gasket was leaking. Not dripping but obviously seeping pretty well enough to cake up
Pic #2- Simply disconnect sensor wire (press tab on wire side of connector) and 4 10mm bolts
I started pulling off the old gasket w/ a flathead carefully. The gasket was brittle and hard.
Pic #3 - Here is a full view of the sensor assembly. Just carefully pull it out of the oil pan as the end float is delicate.
