I was driving down the road when I side swiped a wall. My motor or parts never leaked up until that point. No it's leaking oil and I can't find it. Can some of you Elders, help me out.
Take a bunch of digital photos where you suspect the leak and study them on your computer, post up the photos once you narrow it down. IME some common areas are rear of main oil pan (arch seal), front of engine at oil pump cover, distributor O-ring, valve cover gasket, crank sensor O-ring, front crank seal. Removing the splash pan under the radiator helps see where leaks are coming from up front.
Yes it is a dealer part. Picked one up from Sam at lowes toyota in Atlanta. Any one of the parts guys on this site should have one. Also my distributor was not easy to remove. Had to pull pretty hard to get it out. Don't forget to mark where it is on the block and where the rotor is in relation to distributor. Will make it easier when you put it back in. Unless of course your follow the FSM and set it at top dead center when you remove it. Good luck. My old seal was hard as a rock. Was more like a plastic ring than a rubber seal.
Sent from my iPhone using IH8MUD
